Thus far I think the lows we have had most boats in KY should have been just fine. Starting tonight and into next week, even in southern KY it will be cold. So if you live north and just think the lows are up where you live and have a boat in KY you need to call someone or take off work today and get to it unless you have a good power source and a bilge heater, cabin heat, etc. It was 28 on my way into work in Lexington this morning and is still at 32. ...I still think MOST should have been ok through that but now that it has been freezing a couple nights and yesterday didn't get out of the mid 30s the cold is more than likely starting to soak in, even into storage units. Sooo, if you have been under a rock and are just now seeing this you better get to it!
If you are not winterized or heated you need to act today
- TheOneAndOnlyROOSTER
- Marina/Ramp: Burnt Store Marina Florida
Re: If you are not winterized or heated you need to act toda
I can't imagine anyone not being winterized by now, even sorry azz tire kickers.
TheOneAndOnlyROOSTER wrote:I can't imagine anyone not being winterized by now, even sorry azz tire kickers.
But us and a bunch other...
- image.jpg (643.85 KiB) Viewed 8042 times
- image.jpg (857.79 KiB) Viewed 8042 times
- image.jpg (565.59 KiB) Viewed 8042 times
- image.jpg (797.39 KiB) Viewed 8041 times
- image.jpg (649.54 KiB) Viewed 8041 times
- image.jpg (880.01 KiB) Viewed 8041 times
We did eat good, gotta feed my 6' @ 250lbs...
- image.jpg (865.42 KiB) Viewed 8040 times
- image.jpg (134.06 KiB) Viewed 8040 times
- image.jpg (530.69 KiB) Viewed 8040 times
- image.jpg (877.74 KiB) Viewed 8040 times
- image.jpg (857.62 KiB) Viewed 8040 times
Last edited by TheOneAndOnlyROOSTER on Sun Nov 16, 2014 10:06 pm, edited 1 time in total.
Generator running, firing starboard motor to build heat...
- trim.369E15A6-9099-45C2-BAE2-D5BA918DCD6B.MOV
- (1.06 MiB) Downloaded 2990 times
