Sooo, what is "normal" behavior for the pink Antifreeze?
Last year I went with the cheaper stuff and when I checked it at this cold it was slushy as far as I remember but this stuff is almost solid. I can smush it and it does not look like it expanded any but that kinda freaked me out this am at 6 degrees since the same solution is in the engine block... This year I used the more expensive dow as it boast -50 burst protection etc and has the rust inhibitors but next year if I still have a engine block I think I might mix some of the cheap stuff in with it... :-/ Anyone else ever tested their Boat Antifreeze?
I had checked it the other day at 20 degrees and it was all liquid...
Today when I first went out
(Note: To play video, QuickTime® 6.5 or higher may be required. http://www.apple.com/quicktime/download/ )
DowAntifreeze0103100851a.3g2
(459.14 KiB) Downloaded 1830 times
I decided that vid made it look a little worse than what it was so here is another about 30 minutes later . (it had warmed up three degrees to 9 degrees but I don't think that should matter much) I just wanted to show it can be crushed and squished
DowAntifreeze0103100921a.3g2
(365.46 KiB) Downloaded 1825 times
wow, it is really fun to start both vids and watch them at the same time in the thread... lol :-B
http://lakecumberlandboaters.com/files/ ... 00851a.3g2
On Facebook
http://www.facebook.com/video/video.php ... 065&ref=nf
pourme
Re: Sooo, what is "normal" behavior for the pink Antifreeze?
Post by pourme »
I didn't watch the video but I think the stuff gets slushy....I have seen it that way in the jug.
I sent this to Squak since I know he more than likely has read up on this stuff before and he sent me this link...
http://www.rv.net/FORUMS/index.cfm/fuse ... 222360.cfm
It is some RV people talking about the same issue and it seems to be normal
